Exporting a Hypermesh or Nastran file with the TGrid command:” Meshing> (gui-write-hypermesh-file)” creates the error:” fl_mpi1720.exe has stopped working”. Is there any workaround for this?
- (gui-write-hypermesh-file)” creates the error:” fl_mpi1720.exe has stopped working”. Is there any workaround for this?" target="_blank" rel="nofollow" title="LinkedIn">
- (gui-write-hypermesh-file)” creates the error:” fl_mpi1720.exe has stopped working”. Is there any workaround for this?" target="_blank" rel="nofollow" title="whatsapp">
- (gui-write-hypermesh-file)” creates the error:” fl_mpi1720.exe has stopped working”. Is there any workaround for this?" target="_blank" rel="nofollow" title="reddit">
- (gui-write-hypermesh-file)” creates the error:” fl_mpi1720.exe has stopped working”. Is there any workaround for this?" target="_blank" rel="nofollow" title="facebook">
Tagged: 19, FLUENT Meshing/Tgrid, fluid-dynamics, General, meshing
April 5, 2023 at 2:33 pm
FAQParticipantThis appears to be an issue with parallel TGrid at release 17.2 and up. Exporting the mesh in serial usually works.
- Skewness in ANSYS Meshing
