June 5, 2023 at 7:05 am
FAQ
ParticipantUsing SCDM, you can select many formats to export geometry. While using parasolid format, please select version appropriately. If parasolid does not work, please try STEP, IGES or ACIS. Sometimes it is found that some formats failed to import in SW except ACIS binary format. You can use ACIS binary format during export from SCDM.
- Skewness in ANSYS Meshing
