April 1, 2024 at 11:52 am
FAQParticipantAnsys Discovery Topology Optimization Weight Reduction
Ansys Discovery features best-in-class Topology Optimization Tool, which helps you compute an optimal structural design for a selected region of your model with specific design goals and constraints. Topology optimization is a physics driven optimization that is based on a set of loads and boundary conditions.
Once the simulation is complete you can add the topology optimized body to the structure tree.
You need to click on the highlighted symbol from the Results Arc.
Here’s the example of the faceted topology optimized geometry added to the structure tree.
Discovery allows you to further work on this geometry by Converting to Sub-D or Convert to Solid options.
You can also run a validation simulation on this faceted geometry.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Discovery Quick Tip- Applying Thermal Conductance
- Structural Simulation using Bolt Idealization
