Tagged: 18, fluid-dynamics, General, icem-cfd, Solver output
June 5, 2023 at 7:06 am
FAQParticipantSymptom: Entry File > Export Mesh > To Nastran not visibly although all modules ( Settings > Tools) are enabled. Solution: Use Tab FEA Solve Options > Write/View Input File instead.
- Skewness in ANSYS Meshing
