Explain CAD parameters during CAD Import in Fluent Meshing. How to correct geometry representation in Fluent Meshing?
Tagged: 19.2, FLUENT Meshing/Tgrid, fluent-meshing, fluid-dynamics, General
May 15, 2023 at 8:33 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: import, parameters, tolerance, refine, angle
1. 2056617.mp4
- Skewness in ANSYS Meshing
