May 12, 2025 at 7:21 am
Watch & Learn
ParticipantThe Contact condition enables you to manually define one or more contacts, a type of connection between surface bodies. By default, Discovery automatically generates contacts and sets them to bonded. You can review these generated contact pairs in the Bonded Contacts (default) review tool.
This series of video tutorials explain everything you need to know about contact definition in Ansys Discovery.
- Contact Management in Discovery:Â In this video tutorial, we will see how you can use the contact review tool, to manage the autogenerated contact pairs in Ansys Discovery. From here, you can change the contact definition or modify the behavior.
- Contact Grouping and contact detection distance in Ansys Discovery: In this video, you will learn how you can additionally split the group into individual per-body contacts, or if a single contact references multiple face pairs, split it into individual face pairs.
- Manual Contact creation in Ansys Discovery:Â In the next video, we will see how you can create contacts manually.
Here is a compilation of all the KMs related to contact definition:
- Contact Review tool in Ansys Discovery: Ansys Discovery: Contact Review Tool | Ansys Knowledge
- Thermal conductance in Ansys Discovery: Discovery Quick Tip- Applying Thermal Conductance | Ansys Knowledge, How to Specify different value of thermal conductance on Contact pairs | Ansys Knowledge
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Structural Simulation using Bolt Idealization
- Ansys Discovery: Topology Optimization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery – Defining new material
- How to apply bolt Pretension in ANSYS Discovery?
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
- Discovery Quick Tip- Understanding Contour Settings
