Error while importing geometry in Fluent Meshing on linux. Error:root:not well-formed (invalid token)
Tagged: 2019 R1, FLUENT Meshing/Tgrid, fluid-dynamics, General
March 17, 2023 at 8:58 am
FAQParticipantIf you are using linux then you will have to use this pmdb file. Its limitation on linux. Also make sure you dont have any spaces or special character in the folder (sub folder) names.
- Skewness in ANSYS Meshing
