Tagged: 18.1, fluent, fluid-dynamics, General - FLUENT
June 5, 2023 at 7:06 am
FAQParticipantThis is due to illegal names with spaces and semi-colons. This can be fixed by manually editing the case file in a text editor and replacing spaces and semi-colons with under-scores.
- Skewness in ANSYS Meshing
