Error when launching CFX or Fluent or both. Launcher.exe – Entry Point Not Found “The procedure entry point” …..followed by log text. One error mention Qt5Gui.dll
January 25, 2023 at 7:28 am
FAQ
ParticipantSearch for Qt5xx.dll files under C:Windows folder. for example – Qt5Gui.dll, Move those files to a backup folder (say C:Qt_backup) or rename those files. After that you will be able to launch CFX or Fluent.
