Error: update failed for the solution component in system coupling. The coupled update for system fluid flow (fluent) threw an exception. Update solution failed
April 5, 2023 at 2:32 pm
FAQParticipantCross check set up for model, materials used. Such errors also come as solution is not converged. You may need to decrease the time step size and/or increase no. of iterations per time step.
- Skewness in ANSYS Meshing
