Error: Unable to start Mechanical in Workbench WINDOWS “AnsysWBU.exe encountered a problem. A diagnostic file has been written: C:UsersusernameAppDataLocalTempAnsysWBDumpFile.dmp” and “AnsysWB Module has stopped working: A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.”
January 25, 2023 at 7:28 am
FAQParticipantPossible Resolutions: 1. Close out of all WorkBench sessions. 2. In Windows Explorer in the Address bar type: %appdata% and open the folder ‘Ansys’ 3. Locate the v150, v160, v170, v180 (whatever version corresponds to the version of Ansys you are having issues with). 4. Rename the folder, for example, v150, v160, v170, v180 to v1#0_old. 5. In Windows Explorer in the Address bar type: %temp% 6. Rename the .ansys folder 7. Start a new Workbench session. ——————– Check the graphics card and the driver version you are using. In the RUN command type: dxdiag In the Display tab ensure that your graphics card is a supported Ansys graphics card and that you have the latest graphics driver. In the Display tab ensure that your graphics card is a supported Ansys graphics card and that you have the latest graphics driver. If the output is showing that Intel Integrated Graphics is the primary graphics card taking precedence over your Professional graphics card then do the following: Open up Control Panel > nVidia control Panel > go to 3D settings > Manage 3D settings > Under Preferred Graphics Processor > choose nVidia > Apply If you have an AMD Radeon, Nvidia Matrix or are using the Intel Integrated graphics cards these will generally not work and are not supported. Please visit: http://www.ansys.com/-/media/Ansys/corporate/files/pdf/solutions/it-professionals/platform-support/graphical-display-graphics-cards-tested-17.pdf?la=en If you do have a supported graphics card make sure the driver version is the latest. Please visit the graphics card vendors web site and download and install the newest graphics driver. ———————- Make sure you can resolve localhost. Open up a command window and type: ping localhost If it returns an IPv6 address disable IPv6. It should return something like this for IPv4 Pinging computer_name.domain.com [127.0.0.1] with 32 bytes of data Unlike the familiar IPv4 addresses which are 32 bits long, written in decimal, and separated by periods, IPv6 addresses are 128 bits long, written in hexadecimal, and separated by colons. An example might be: 3ffe:1900:4545:3:200:f8ff:fe21:67cf Step 1 Open up the properties of you network adapter and uncheck the IPv6 checkbox only. Doing, this however, only unbinds IPv6 from that particular network adapter. It doesn’t disable IPv6 in Windows and it doesn’t solve the common problems with IPv6 in Windows. To cleanly disable IPv6 a registry key must be added. Go to the following web site for a registry file that will add a registry key to disable IPv6 NOTE: MAKING ANY CHANGES TO THE WINDOWS REGISTRY COLD CAUSE YOUR SYSTEM TO BECOME UNSTABLE. CONTACT YOUR IT ADMINISTRATOR FOR ASSISTANCE. ANSYS IS NOT RESPONSIBLE FOR ANY ISSUES CAUSED BY EDITING OR MAKING CHANGES TO THE WINDOWS REGISTRY. Step 2 https://support.microsoft.com/en-us/kb/929852 Verify that IPv6 is disabled by typing ipconfig /all from the command prompt. The output should only show IPv4 addresses If you are running Window 8.1 or higher do an Internet search for disabling IPv6 via manually editing the registry. When you have disabled IPv6 a reboot is necessary. Diagnostics Needed: CLIENT: Please launch the ANSLIC_ADMIN Utility, click View Status/ Options, then Gather Diagnostic Information. Click “Yes” when prompted. This will gather some diagnostic information that should help figure out the problem. Please zip the directory which is created and upload to the Service Request, the path will show in the ANSLIC_ADMIN Utility window. Please also provide screenshots of any error messages. Please refer to this Animated Tutorial for assistance with how to obtain the diagnostics on the Client side and for license servers running Version 15 or earlier version of the ANSYS Inc. License Manager. Gathering Client-Side Diagnostics for ANSYS http://youtu.be/9CcJMhtim9Q SERVER: If your License Server is running version 16 of the ANSYS Inc. License Manager, please follow these steps for gathering the server side diagnostics. For WINDOWS please select – Start /All Programs /ANSYS, Inc. License Manager /License Management Center This launches ANSYS License Management Center Click Gather Diagnostic Information / Save to File Then the browser should save the zip file in to the default folder (typically your downloads folder) If browser shows an option to save or open then please choose save file.
