Error: This is a post-processing only executable. Whenever I try to simulate anything in Ansys Fluent 2022 R1, the minute I start “Run Calculation” after setting up the case, this error is showing up. This is a post-processing only executable but the same case file is running perfectly in other versions and other machines.
March 17, 2023 at 9:00 am
FAQParticipantYou are launching Fluent 2022 R1 in ‘Pre-Post’ mode. To run the solver, please uncheck the option ‘Pre/Post Only’ in Fluent launcher and run Fluent 2022 R1.
