Error: The job must be run on a single machine When trying to run Icepak Distributed via RSM you see this error in the RSM log file: This job must run on a single machine
Tagged: 18.2, HPC/Parallel, Icepak - SYS, Installation/Licensing/Systems, rsm
June 5, 2023 at 7:05 am
FAQParticipantIcepak, any version, cannot run distributed using RSM. You must run it on a single machine This issue has been addressed in Release 19
