Error : ” System.Net.SocketException:No connection could be made because the target machine actively refused it 127.0.0.1:9192.
March 17, 2023 at 9:01 am
FAQParticipantDisable IPV6 and Enable IPV4. ping hostname.company.com (IP_ADDRESS) Verify that the IP_ADDRESS that was returned is the correct IP_ADDRESS for your hostname 127.0.0.1 localhost IP_ADDRESS hostname.company.com hostname (Where IP_ADDRESS hostname.company.com hostname is the IP ADDRESS on the local machine name and then add the Fully Qualified Domain Name (FQDN)) Make the desired updates and save the file. restart the network services and RSM service.
