Error: SchedulerAdapter: SetHeadNode error: No job templates found; there should be at least one job template, the default job template..
Tagged: HFSS - SYS, hpc, HPC/Parallel, Installation/Licensing/Systems, Other
June 5, 2023 at 7:06 am
FAQParticipantAdd “C:Program FilesMicrosoft HPC Pack 2012Bin” to PATH environment variable. ex: Path=%SystemRoot%system32;%SystemRoot%;%SystemRoot%System32Wbem;C:Program FilesMicrosoft HPC Pack 2012Bin Reason: jobtemplate.exe binary is in the Microsoft HPC Pack 2012 installation folder and needs to be in the PATH
