Error occurring in CFX Solver section before first iteration: Details of error:- —————- Error detected by routine PEEKI CDANAM = NMONS CRESLT = NONE Current Directory : /FLOW/CONTROL/OUTPUT/MONITOR +——————————————————————–+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR
Tagged: 18.1, cfx, fluid-dynamics, General, General - CFX, Solver Error code
January 25, 2023 at 7:16 am
FAQParticipantIf user surfaces are defined in CFX-Pre (for use in live solution monitoring or for use in turbine film cooling) and the job is run on a cluster, the job needs to be able to access the path to the location of the user surface .csv files. If it can’t, it may generate an error as listed above.
- Skewness in ANSYS Meshing
