April 5, 2023 at 2:32 pm
FAQParticipantDuring the installation of ANSYS Products the files in the folder C:Program FilesANSYS IncShared FilesLicensingwinx64 are updated. If for some reason the installation executable is not able to update the files it creates a subfolder named “update”. To fix the error “Not connected to a license server for licensing actions”, you need to copy/paste the files from C:Program FilesANSYS IncShared FilesLicensingwinx64update to the folder C:Program FilesANSYS IncShared FilesLicensingwinx64
