January 25, 2023 at 7:28 am
FAQ
ParticipantThe workaround is to add the option -nmon to the Fluent launch command. In the Fluent Launcher Environment tab you can add the following variable if running interactively FLUENT_SKIP_MONITOR_RING=1
- Q: How do I set the license server from my client machine?
