March 17, 2023 at 9:01 am
FAQ
ParticipantThe Parasolid file moved to linux environment needs to be converted into unix format before importing in Mechanical APDL. When I ran this command: tr -d ‘r’
Box_u.x_t and saved the file into unix format, I was able to import it successfully. Kindly try the same. User may also use: “dos2unix Box.x_t†(without quotes) in place of previous command.
- Q: How do I set the license server from my client machine?
