April 5, 2023 at 2:33 pm
FAQParticipantThis ACT is available on the ANSYS App Store of ansys.com website, for V17.x and V18.x. The following error message may happen when trying to update Fluent Meshing : User OnUpdate Callback Error: Local variable ‘sfPath’ referenced before assignement To solve this one, please change the decimal symbol on your machine, from comma (,) to point (.) as explained in the ACT document WBPolyMeshingForFluent.pdf To change Decimal Symbol: Control Panel > Region and Language > Formats -> Additional settings > Numbers > Decimal Symbol
- Skewness in ANSYS Meshing
