Error message while opening rst file containing super elements. Error message “Failed to make geometry for domain ‘Default Domain’.”
June 5, 2023 at 7:05 am
FAQ
ParticipantIf RST file contain CMS super element then it will not load and will give error. Currently this is limitation.
- Skewness in ANSYS Meshing
