Tagged: 18.1, cfx, fluid-dynamics, General - CFX, User Function
June 5, 2023 at 7:05 am
FAQParticipantWhen running a calculation with CFX, the error message “Need at least 2 data pairs for interpolation” appears because there is a User Function with one line only (one data pair). A User Function needs two lines at least, even if it is not used in the setup. Please delete the User Function or add a second data line.
- Skewness in ANSYS Meshing
