error message: error while loading shared libraries: libXm.so.3: cannot open shared object file: No such file or directory prevents ANSYS Mechanical to run on Linux OS.
March 17, 2023 at 9:01 am
FAQ
Participant* install openmotif22-libs-2.2.4-138.18.1.x86_64.rpm * this is not delivered with OS * you do not need to install OpenMotif, only install libraries
- Q: How do I set the license server from my client machine?
