ERROR: /lib64/libc.so.6: version `GLIBC_2.14′ not found (required by /opt/AnsysEM/AnsysEM19.5/Linux64/Delcross/libPythonQt-Qt5-Python3.4.so.3)
March 17, 2023 at 9:01 am
FAQParticipantANSYS EMIT and Savant 2019R3 are not supported on RHEL6.x platforms. The embedded QT packages require GLIBC_2.14
