Licensing
Licensing
Error: CAPRI_NOLICENSE Not able to import CAD file into ANSYS Design modeler or Spaceclaim
    • SolutionSolution
      Participant
      Problem with Multiple CADnexus installed for multiple ANSYS Versions: Solution: How to setup the system for multiple versions of ANSYS, CATIA V5 & CADNexus CAPRI 1. Uninstall all versions of CADNexus CAPRI from your system. 2. Install CADNexus CAPRI interface, select “No” when prompted to “Add CAPRI environment variables to your system?” 3. Create an ANSYS Workbench startup batch file (.bat) that contains the following to run ANSYS Workbench with specified version CADNexus CAPRI.
      1. 2055267.zip
