June 5, 2023 at 7:05 am
FAQParticipantIf for some reason, the case and data file in WB have different names then CFD Post throws this error. Post, when reading in a .dat file, looks for a .cas file with the same name. If it can’t find it, it throws an error about no mesh file available. As workaround make the name same and you can read it in CFD Post.
- Skewness in ANSYS Meshing
