Error “…Cannot find thermo database file …Reverting to default…” while reading PDF Table. How to link a specific thermodynamic database file to a case?
Tagged: BCs & Interfaces, error, fluent, fluid-dynamics, materials, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantIf you import a reaction mechanism (in Chemkin format) or if you need specific species in your solution, which are not part of the default thermodynamic database (thermo.db), you typically use a specific thermodynamic database file in a fluent case with a PDF based combustion model. If you now move such a fluent case to a different drive / folder, fluent often fails to find the specified thermodynamic database file: “… Cannot find thermo database file … Reverting to default …” This can be solved by specifying the updated path to the thermodynamic database with: (rpsetvar ‘prepdf/default-thermo-db-fname “/path/custom_therm.dat”) This change (path to thermodynamic database) is saved in the fluent case file. Keywords: Fluent, species, reaction, Non-Premixed Combustion, PDF, thermo database file, thermo.db
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Model setup: Setting up chemical reactions
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
