March 17, 2023 at 8:59 am
FAQParticipantIn Fluent the Error message “Error at Node 0 : Specific_Heat_by_T_Integral : invalid upper bound T1 <=0", at the end of the initialization or at the calculation start, means a general divergence. It can be due to a bad mesh quality, or a setup problem. The option Solution > Check Case may help.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
