September 22, 2023 at 11:02 am
FAQParticipantIn order to use all designs defined in this project. How to define project variables? select from the menu, Project -> Project Variables… -> Project Variables tab -> Add… -> Add Property When you create a variable in the Project, $ is automatically created in front of the variable. You can use the “$ variable_name” for all Maxwell Design. Keywords : Maxwell, Orientation, Project Variables, Maxwell Design
1. EM_FAQ_HowToDefineProjectVariables_Maxwell.pdf
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- EM FAQ: How to define project variables that apply to all designs?
- What are the default boundary conditions in different solvers?
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- Vacuum Thermal Modeling in ANSYS Icepak
- ANSYS Icepak: How to delete unused materials in a project?
- ANSYS Icepak: O-grid meshing issues
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
