Each time ANSYS Electronic Desktop is opened a series of errors are written to the Windows Application Event log which include a reference to pawin32.dll
March 17, 2023 at 9:01 am
FAQParticipantCheck that each user running the software has read, write and execute permissions for all files in the directories. C:users%username%AppDataLocalPreEmptive SolutionsPA Settings and C:ProgramDataPreEmptive SolutionsPA Storage
