During installation, the following dialog appears: Dialog: Windows XP Setup Please go to the Control Panel to install and configure system components.
March 17, 2023 at 9:01 am
FAQParticipantThis is caused by missing files in the directory where the Ansys installation was extracted. – Re-download and extract using Winzip. – Check the box that says “Use folder namesâ€. – Run Setup.exe.
