During an interactive Multizone-ICEM meshing session, I find that the ICEM mesh looks great and passes all the quality metrics, but when ICEM is closed and Multizone continues, I get the message: “An inconsistency in the manual source/target selection is detected. Please check that source and target faces are properly selected.” What am I doing wrong?
March 17, 2023 at 8:58 am
FAQParticipantThe unstructured version of the Hexa mesh is missing from the ICEM project. This has to be done in ICEM before closing the ICEM application and saving the project files. Most likely, you forgot to right-click on Premesh after the Hexa mesh was generated in and select “Convert to Unstructured mesh” Only the unstructured mesh can be read by ANSYS Meshing/Multizone
- Skewness in ANSYS Meshing
