June 6, 2022 at 8:33 am
FAQParticipantIn the Interface Conditions>Contact menu, under Contact Behavior, there is a slider called ‘Search Settings’ (Show All Properties’ button activated). The slider can be position to ‘Fast’ to get a quick first result. However, the result will not be accurate and the contact can be detected far from the mold. By moving the slider to ‘Safe’ will increase the accuracy of the contact detection.
- Skewness in ANSYS Meshing
