Draw Mesh’ option is not retained when I create a post-processing object (contour, particle track, …)
Tagged: 19, fluent, Fluent-CFDPost IO, fluid-dynamics, NA, post-processing
April 5, 2023 at 2:32 pm
FAQParticipantThis is the expected behavior from development perspective The workaround is to create a scene containing both the mesh and the desired post-processing tool This scene can later be used for single display, or automated animations
- Skewness in ANSYS Meshing
