April 13, 2023 at 7:32 am
SolutionParticipantAttached document: It basically means that only SafeNet (makers of the dongle) can write to the memory on the dongle and it is a read-only device.
1. 2059352-Certificate_of_Sentinel HL_Memory_Volatility.pdf
