Modeling & Meshing
Modeling & Meshing
Does the fracture mesh override base mesh control?
    • FAQFAQ
      Participant
      Yes. The fracture mesh settings will override the base mesh control, because it is a post operation that is performed on the existing base mesh. To obtain a refined mesh, you can reduce the growth rate setting for the fracture mesh.
