Does elastic foundation stiffness – per- area value is acting in both the axial and shear directions, or is it on axial and free in shear direction?
June 5, 2023 at 7:05 am
FAQParticipantThe “Elastic Foundation Stiffness” (EFS) or “Elastic Support” is a way of specifying a spring stiffness per unit area that only acts in the direction normal (axial) to the face of the element.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
