Does elastic foundation stiffness act in both the axial and shear directions, or is it on axial and free in shear direction?
June 6, 2022 at 9:58 am
FAQParticipantThe “Elastic Foundation Stiffness” (EFS) or “Elastic Support” is a way of specifying a spring stiffness per unit area that only acts in the direction normal (axial) to the face of the element.
