April 5, 2023 at 2:32 pm
FAQParticipantNo since the release 18.2 and for the specific case is if one has retained the design points (so the solution files are still there) and change something in CFD Post, it should just reuse the retained design points to go thru and update only CFD Post. Prior to Release 18.2 all all design points needs to be rerun.
- Skewness in ANSYS Meshing
