June 6, 2022 at 9:58 am
FAQ
ParticipantHere are two tips on meshing thin bodies:
1 Check the defeaturing size. Reduce the defeaturing size below the thin dimensions to capture the thin features properly.
2. Check mesh size. If it is too coarse on the thin feature, use fine sizing.
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Merging Mesh Nodes
