Tagged: 2019 R1, act, mechanical, static, structural-and-thermal, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantYes, here is an ACT developed for tire simulation. The “doc” folder contains several examples and tutorials of tire simulation. https://catalog.ansys.com/product/5c13bc33393ff6712829bcfe/tire-simulation#download
