Do you have an ANSYS example demonstrating a procedure for including thermal radiation and conduction across an airgap? I am assuming that the gap is too small to allow convection, so I plan to treat it as a conduction solid. I do expect radiation to play a significant part in overall heat transfer.
March 17, 2023 at 1:11 pm
Solution
ParticipantPlease refer to the attachment(s) to access the Solution.
1. 304326.pdf
2. 304326.zip
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
