June 5, 2023 at 7:04 am
FAQ
ParticipantFrictionless contact does not offer any resistance to sliding. Under forced based loading that produces sliding, this might contribute to convergence troubles with hot spots on the surface. Use of frictional contact with low friction coefficient might stabilize this situation.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
