September 26, 2022 at 10:15 am
SolutionParticipantDownload the file here
An application example to find the structural performance of the tie-rod connector is investigated. The stresses and deformations are checked in both Explore and Analyze mode. Whereas a parametric study in explore mode is also included to look at the effects of the fillet radius.This project requires release 2020 R2 or newer. The below images are von mises stress contour and parametric study for Discovery explore and von mises stress contour for analyze mode.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Discovery – Defining new material
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery Quick Tip- How to Export to Fluent
