Tagged: Analyze-FAQ, Ansys Discovery, Explore-FAQ, thermal
September 26, 2022 at 10:15 am
SolutionParticipantDownload the file here
Application example of the solid temperature in a board with a heat source and a heat sink is simulated. The impact of changing the shape and size of the heat sink, within the constraints of the enclosure, on the max temperature on the surface of the board can be studied. This project requires release 2020 R2 or newer.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- Applying Thermal Conductance
