Tagged: Analyze-FAQ, Ansys Discovery, Explore-FAQ, thermal
September 26, 2022 at 10:15 am
Solution
ParticipantDownload the file here
Application example of a cold plate utilizing a convection region with a modified film coefficient to replicate the water flow through the cooling pipes. Below are the results of temperature distribution over the cold plate model. This project requires release 2020 R2Â or newer.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Structural Simulation using Bolt Idealization
- Ansys Discovery: Topology Optimization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery – Defining new material
- How to apply bolt Pretension in ANSYS Discovery?
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
- Discovery Quick Tip- Understanding Contour Settings
