September 26, 2022 at 10:15 am
Solution
ParticipantDownload the file here
Application example of a simple loading being applied to a replacement hip. The high-stress locations and overall part deformation can be visualized and measured using both Explore and Analyze mode. This project requires the release 2020 R2 or newer. The below images are displacement contours for Discovery explore and analyze mode.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Ansys Discovery: Topology Optimization
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery – Defining new material
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
- Ansys Discovery: Activating Beta Feature
