September 26, 2022 at 10:15 am
SolutionParticipantDownload the file here
Application example of a snap-fit buckle with face displacement as an alternative to deformation by non-linear contact done using both explore and analyze mode. This project requires release 2020 R2 or newer. The below images are displacement contours for Discovery explore and analyze mode.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Ansys Discovery: Topology Optimization
- Structural Simulation using Bolt Idealization
- Discovery – Defining new material
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
