September 26, 2022 at 10:15 amSolutionParticipant
Download the file here
Application example of a structural simulation of a clutch housing and frame to understand the frame deformation under vertical load using both explore and analyze mode. This project requires release 2020 R2 or newer. The below images are displacement contours for Discovery explore and analyze mode.
- Ansys Discovery: Topology Optimization
- Discovery: Porous media coefficient calculator
- In-Depth – Fluids Simulation using Ansys Discovery
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Structural Simulation using Bolt Idealization
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
- Ansys Discovery: Activating Beta Feature
- Discovery Analyze Mode – Unable to view or change material properties.
- Discovery Refine mode – Viewing mesh
