September 26, 2022 at 10:15 am
SolutionParticipantDownload the file here
Application example of the deformation of plastic housing with cut-outs is studied. The change in deformation under different load locations and cut-out locations/shapes can be explored. Below are the deformation results of this analysis. This project requires release 2020 R2 or newer.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Discovery Quick Tip- Understanding Contour Settings
- Ansys Discovery: Topology Optimization
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- Applying Thermal Conductance
